2004 Ford Taurus Hiss Over Bumps
SARISHC965
I have Ford Taurus SE 2004. Mileage is 56000. When the car goes over humps slowly, I can hear a sound 'hiss' for short time. However I do not feel any discomfort during long drives due to bumps or anything like that.
When I contacted mechanic he suggested me that I should change front struts.
Please let me know when struts needs to be replaced and what is impact of not changing in the scenario I am experiencing.
Thanks & Regards,
Sanju
Jun 5, 2007 at 1:42 PM
RUDPRO
  • 224 POSTS
How long they last depend on the quality of the struts and what kind of driving you do. Struts generally last 50,000-60,000 miles. If you do a lot of smooth highway driving they should last longer. Does your car handle OK during sharp cornering (does it roll or sway)? Does the front end dive when braking hard? If not and you feel the ride is smooth you probably don't need them yet. You might want to think about replacing them in the next 10,000-12,000 miles though.
Jun 5, 2007 at 3:27 PM
Suggested Repair
Do not replace the front struts yet if cornering is stable, the front end does not dive under hard braking, and the ride remains smooth. Recheck handling and consider replacement within the next 10,000-12,000 miles.
Conversation Summary
The owner of a 2004 Ford Taurus SE with 56,000 miles hears a brief hiss when going slowly over bumps but reports no ride discomfort. A mechanic recommended front struts. The expert said strut life is typically 50,000-60,000 miles depending on quality and driving, and that replacement can wait if the car does not roll in corners or dive when braking hard and the ride is smooth, with replacement considered in the next 10,000-12,000 miles.
