Well, you're not leaking/No air in it/no slipping belt/radiator not clogged/Fan clutch good/Radiator cap checks out and all those stuffs were changed. Makes me believe on what I've mentioned.
Could also be a problem with:
Bad new thermostat
Improper coolant mixed
Clogged exhaust system
Retarded or advance Ignition timing
Dragging brakes ( Caliper sticking and parking brake not releasing)
These two tests bloc chek and pressure test are use to ID an internal leak causing overheating problems.
Tuesday, March 13th, 2007 AT 8:42 AM
