I recently purchased 134a refrigerant and 134a+ in order to recharge my air conditioner. I do not have an owner's manual: where is the low pressure port located and can I use this type of refrigerant in my airconditioner? The can warns not to use the contents in R-12 A/C systems. Thank you!
1998 Ford Taurus A/C Recharge Port
ok the port is where you make the connection. maybe i should be a little more specific. the port for the low side is smaller, yet the line is thicker than the high side.
Suggested Repair
The 1998 Taurus already uses R-134a, so R-134a refrigerant is appropriate and R-12 is not. Connect only to the low-side service port: the smaller fitting on the thicker line, on the passenger side near the firewall. Lift the wire harness if needed. The high-side port is the thinner line near the power steering pump. Follow a proper A/C recharge procedure.
Conversation Summary
The owner of a 1998 Ford Taurus 3.0L asked where the low-pressure A/C port is and whether purchased R-134a refrigerant is safe, noting the can warns against use in R-12 systems. Experts said the system already uses R-134a. They identified the low-side connection as the smaller port on the thicker line, located on the passenger side near the firewall, and said the high-side port is by the power steering pump.
