Cleaning A/c condenser
FORD TAURUS
BANJO1234
My 1999, Ford Taurus, 3.0 L, 167,000Km, is overheating when the a/c is on. I have checked the fans, and both are working when the a/c is on. I have been told I might try cleaning bugs and dirt from the condenser. However it is very tight in the front, so access is difficult. Is there a trick to accessing and cleaning the a/c condenser?
Jul 24, 2007 at 4:24 AM
2CARPRO JACK
  • 11,533 POSTS
You can try removing the cooling fans and washing it out backwards with a hose, that will clean out the radiator as well
Jul 25, 2007 at 12:46 AM
BANJO1234
I did as you recommended, to clean the A/c condenser on my 99 Taurus, and it works perfectly now!!! There was some build up of sand and grit, not alot, but obviously enough. The gauge does not move from the center line at all now !! Thank you so much.
Jul 27, 2007 at 1:34 AM
BANJO1234
Here is what I did: I took a thin stick about 24" long, and 1/4" X 1" and gently rubbed off the grit from the front of the condenser and radiator. About a 1/4 cup of sand/dirt was on the ground when I completed this step. I then took my compressed air gun and sprayed both till no more dust came off. Not alot of grit there, but I guess just enough to plug the fins, because it is perfect now, in very hot weather!
Thanks again!
Jul 30, 2007 at 1:27 AM
