However, I was concerned about getting a ticket for driving home with my dome light on, so I opted to take it out. Of course, it was hot, so I used my key to pry one end of it out to let it cool. In the process, I blew the fuse, which is also not a problem to fix.
Now for the problem. When I blew the fuse for the dome light, I also screwed up something in my windows. None of them work. I checked the fuse and it's not blown, so I'm hoping it's just a relay. The problem is, I can't find it and, when I do, I don't know how to tell if it's bad. According to the drawings from alldata. Net, the relay in position 38 is a "one touch window down relay". At first glance, I assumed that it was just for the function of tapping the button and having the window go all the way down without holding it, but I couldn't find any others that were for window operation, so could this relay cover more than just the "one touch" function? If not, can you give me an idea of which other fuses or relays to check? Also, is there some secret trick to getting them out easily? I tried to pull that one out but I'm having a hard time getting to it, and my two little fingers just ain't cuttin' it!
Thanks in advance for any help! :)
SPONSORED LINKS
Tuesday, November 27th, 2007 AT 11:36 PM
