1999 Ford Taurus Oil Leak
LER281
I have a 1999 Ford Taurus and as I was driving, everytime I would press the gas pedal, I would hear some scratchy noise. Like when a fan is blowing and you put a pen in the way and it sounds kind of like clicking at the same time... Well like that. Then the oil light came on. So I pulled over in to the nearest store i could find, and I filled up with oil. I was heading home and about 15 minutes later I heard it again. So I went to AutoZone. The guy was clueless, and I Refilled it with oil just to make it home. Well as I did that I looked under the car and My oil was leaking... Whats wrong with my car? Is is something big?
Aug 11, 2007 at 3:48 PM
  • 75,988 POSTS
[quote:20d6391ee0="LER281"]I have a 1999 Ford Taurus and as I was driving, everytime I would press the gas pedal, I would hear some scratchy noise. Like when a fan is blowing and you put a pen in the way and it sounds kind of like clicking at the same time... Well like that. Then the oil light came on. So I pulled over in to the nearest store i could find, and I filled up with oil. I was heading home and about 15 minutes later I heard it again. So I went to AutoZone. The guy was clueless, and I Refilled it with oil just to make it home. Well as I did that I looked under the car and My oil was leaking... Whats wrong with my car? Is is something big?[/quote:20d6391ee0]
Sounds like the leak is coming from the valve cover/s the way you describe it, that fast and if its the oil pan the engine has to be running.
Or I could be wrong and its the oil drain plug/oil sending unit/pan/oil filter housing/front and rear seals.
Aug 12, 2007 at 6:16 PM
LER281
[quote:91f419570a="rasmataz"][quote:91f419570a="LER281"]I have a 1999 Ford Taurus and as I was driving, everytime I would press the gas pedal, I would hear some scratchy noise. Like when a fan is blowing and you put a pen in the way and it sounds kind of like clicking at the same time... Well like that. Then the oil light came on. So I pulled over in to the nearest store i could find, and I filled up with oil. I was heading home and about 15 minutes later I heard it again. So I went to AutoZone. The guy was clueless, and I Refilled it with oil just to make it home. Well as I did that I looked under the car and My oil was leaking... Whats wrong with my car? Is is something big?[/quote:91f419570a]
Or I could be wrong and its the oil drain plug/oil sending unit/pan/oil filter housing/front and rear seals.[/quote:91f419570a]
Thanks for your help. I'll check it out. I wasnt too sure you know.
Aug 13, 2007 at 8:59 AM
Suggested Repair
Inspect the valve covers first for a fast oil leak, then check the drain plug, oil sending unit, oil pan, filter housing, and front and rear seals. Do not keep driving with low oil.
Conversation Summary
The owner of a 1999 Ford Taurus heard a scratchy noise when pressing the gas, then the oil light came on. After adding oil twice, oil was seen leaking under the car. The expert said a leak that fast may be from the valve covers, or possibly the drain plug, oil sending unit, pan, filter housing, or front and rear seals.
