1994 Ford Taurus OBD Connector Location
TULLHEAD12
I can't find the outlet for and OBDII tester in my sisters 1994 Ford Taurus. It is not in the driver's compartment where it usually is. I don't own a ford so I am not familiar with the location. Any Help
Nov 21, 2007 at 7:32 AM
TAURUSWHEEL
  • 718 POSTS
You have obdI, the connector is located in the engine compartment, right side firewall on the black plastic cover above the a\c dryer.. there may be two connectors if you have abs brakes,, the one for the obdI will have an extra pigtail.
Nov 21, 2007 at 8:28 AM
Suggested Repair
This 1994 Taurus uses OBD-I, not OBD-II. Look in the engine compartment on the right-side firewall, on the black plastic cover above the A/C dryer. If the car has ABS there may be two connectors; the OBD-I connector has an extra pigtail.
Conversation Summary
The owner could not find an OBD-II port in the driver's compartment of a 1994 Ford Taurus. The expert explained the vehicle uses OBD-I and the connector is in the engine compartment on the right firewall above the A/C dryer, with an extra pigtail if ABS is present.
