1996 Ford Taurus Fuel Filter Location Fix
BURNINMOTION
i have a 1996 ford taurus and i was wondering where the fuel filter is on this model. thanks!
Sep 13, 2006 at 3:41 AM
NOS
  • 320 POSTS
the fuel filter is mounted on the passanger side on the frame just in fronty of the rear wheel you will need a 5/16 socket and a flat screw driver to pry the clips out and the socket is to remove the clamp that holds the filter.(NOS) 8) PS don't break the fuel lines they are plastic.
Sep 16, 2006 at 5:59 AM
Suggested Repair
The fuel filter is on the passenger-side frame just ahead of the rear wheel. Use a 5/16 socket to remove the clamp and a flat screwdriver to pry out the clips. Do not break the plastic fuel lines.
Conversation Summary
The owner of a 1996 Ford Taurus asked where the fuel filter is located. An expert said it is mounted on the passenger-side frame just in front of the rear wheel and that a 5/16 socket and flat screwdriver are needed to release the clamp and clips. The expert also warned not to break the plastic fuel lines.
