1997 Ford Taurus O2 Sensor Location
AZCARDINALS602
  • 10 POSTS
how do i replace a o2 senser on my car ? where is it located at ?
Sep 17, 2007 at 10:46 AM
SERVICE WRITER
  • 9,123 POSTS
There should be two of them one before the converter and one after it as it is measuring the converter's performance. Both are in the exhaust system, the front one may be as far up as the exhaust manifold.
Sep 17, 2007 at 12:23 PM
AZCARDINALS602
  • 10 POSTS
thank you so much ?
would you know why evertime i push my brakes
my car seems like the motor or the brakes move when pushing them or turning to the right only
its kind of like the engine mount is miss could you help me with this quetion
Sep 18, 2007 at 7:07 AM
SERVICE WRITER
  • 9,123 POSTS
I'm not following, the car pulls when you brake?
Sep 18, 2007 at 11:49 AM
AZCARDINALS602
  • 10 POSTS
1997 Ford Taurus gl
127,000 miles
4 cly
no its like when i push the brake before it stops it fills like i etheir ran something over or the car skips before stoping but does come to a full stop?
Sep 18, 2007 at 12:18 PM
SERVICE WRITER
  • 9,123 POSTS
I think we are getting closer.
So when you brake the brake pedal maybe vibrates or goes up and down and is probably worse at brakeing from hgher speeds?
Sep 18, 2007 at 12:43 PM
AZCARDINALS602
  • 10 POSTS
no that would be the rotors before it comes to a stop the car hops or something like that the brakes hops or engine almost like i ran something over happens right before it comes to a stop
Sep 22, 2007 at 6:15 PM
SERVICE WRITER
  • 9,123 POSTS
Like the abs is being activated? False absing?
IF so have the codes pulled from the BCM.
Sep 22, 2007 at 11:36 PM
Suggested Repair
The two oxygen sensors are in the exhaust: one before the catalytic converter and one after it; the front sensor may be as far forward as the exhaust manifold. For the hop or skip just before a stop, have brake control module codes read to check for false ABS activation.
Conversation Summary
The owner of a 1997 Ford Taurus asked how to replace an oxygen sensor and where it is located. The expert said there are two sensors in the exhaust, one before the converter and one after, and that the front sensor may be at the exhaust manifold. The owner then described a hop or skip just before the car stops, mainly when braking or turning right, not a pedal vibration. The expert suggested possible false ABS activation and recommended pulling codes from the brake control module.
