1999 Ford Taurus Wagon No Heat
KSS
1999 Ford Taurus Wagon with about 97,000 miles heat does not work. I have checked all the hoses going in and out of the heater core and they all feel hot. When you first turn on the heat it is warm then within seconds turns cold. Do you have any suggestions on what could be the problem?
Mar 21, 2006 at 4:56 AM
BART6180
sounds like you need a thermostat
Mar 21, 2006 at 1:45 PM
RUXBAN
  • 5 POSTS
If you smell coolant, you probably need a new heater core.
Otherwise you simply need to add more radiator fluid.
Mar 22, 2006 at 3:57 PM
GODBEAR839
  • 77 POSTS
Have you flushed the system out? if not I would start there. Then turn on the car and warm it up. If the heater hoses (both) get hot then it could be the switch to mix the air under the dash if one is getting hot and the other is not . then you may have a blockage in the heater core itself and it will need replaced.But it sounds like the heater core has some kind of blockage in it. And of course be careful once you get it hot. It's scalding hot water and it's typically under pressure so if you loosen anything up it will shoot out possibly burning you.
Mar 27, 2006 at 3:30 AM
Suggested Repair
Flush the cooling system, then warm the engine and compare both heater hoses. If both get hot, check the under-dash air mix (blend door) control. If only one hose gets hot, the heater core is likely blocked and should be replaced. Use caution around hot, pressurized coolant.
Conversation Summary
A 1999 Ford Taurus wagon with about 97,000 miles has no lasting heat: it starts warm, then quickly turns cold, even though the heater hoses feel hot. Users suggested a thermostat, low coolant, or a heater core. The expert recommended flushing the system, comparing both heater hose temperatures after warmup, and checking for a blocked heater core or a faulty under-dash air mix control.
