98 ford tarus se 3.o 6cl. 71000 m. heater problems
2012 FORD
FELD1962
i have put in new themostat flushed out heater core and it still blows out cold air
Feb 13, 2007 at 3:09 AM
TAURUSWHEEL
  • 718 POSTS
An issue a lot of people seem to be having is the waterpump, the internal blades that push the water wear down to the point where the car doesn't overheat, but the water can't be pushed thru the core good enough... this issue years ago was never a problem, just like most now, parts ain't what they used to be..
Feb 13, 2007 at 10:04 AM
FELD1962
[quote:0f2c58bf64="TaurusWheel"]An issue a lot of people seem to be having is the waterpump, the internal blades that push the water wear down to the point where the car doesn't overheat, but the water can't be pushed thru the core good enough... this issue years ago was never a problem, just like most now, parts ain't what they used to be..[/quote:0f2c58bf64]
I got it to work had to take it to my repair man he put lots of pressure through the cooling tank resiivor heats real good hope it lasts What I Don"t under stand is that was the themostat realy bad Thanks for the info.
Feb 13, 2007 at 11:05 AM
