2000 Ford Taurus Low Fuel Pressure
SMYLIE74
I have a 2000 taurus, 113,000 miles that is no getting enough feul pressure. I have had it to 4 mechanics and still unable to resolve problem. When driving around 40-55 mph it bogs down, acts like it's running out of gas or it will stall while driving down the road and u have to pump the gas pedal to get it going again. Also sometimes it will idle and sometimes it doesn't weather it's in park or gear and sometimes it doesn't want to start it will just turn over or start for a second but die cause it's not getting enough feul, you can start it with starting fluid though. I have replaced the feul pump and filter twice, the relay switch has been replaced, plugs and wires and injectors cleaned. Please help!!!!!! Thanks for your time in reading my question
Sep 8, 2007 at 11:42 AM
  • 75,988 POSTS
[quote:ae3a9a9a18="smylie74"]I have a 2000 taurus, 113,000 miles that is no getting enough feul pressure. I have had it to 4 mechanics and still unable to resolve problem. When driving around 40-55 mph it bogs down, acts like it's running out of gas or it will stall while driving down the road and u have to pump the gas pedal to get it going again. Also sometimes it will idle and sometimes it doesn't weather it's in park or gear and sometimes it doesn't want to start it will just turn over or start for a second but die cause it's not getting enough feul, you can start it with starting fluid though. I have replaced the feul pump and filter twice, the relay switch has been replaced, plugs and wires and injectors cleaned. Please help!!!!!! Thanks for your time in reading my question[/quote:ae3a9a9a18]
What about the fuel pressure regulator, also the injectors might not energizing because the computer is not receiving an ignition signal -could be a CPS problem.
Sep 8, 2007 at 2:01 PM
SMYLIE74
[quote:b743418c67="rasmataz"][quote:b743418c67="smylie74"]I have a 2000 taurus, 113,000 miles that is no getting enough feul pressure. I have had it to 4 mechanics and still unable to resolve problem. When driving around 40-55 mph it bogs down, acts like it's running out of gas or it will stall while driving down the road and u have to pump the gas pedal to get it going again. Also sometimes it will idle and sometimes it doesn't weather it's in park or gear and sometimes it doesn't want to start it will just turn over or start for a second but die cause it's not getting enough feul, you can start it with starting fluid though. I have replaced the feul pump and filter twice, the relay switch has been replaced, plugs and wires and injectors cleaned. Please help!!!!!! Thanks for your time in reading my question[/quote:b743418c67]
What about the fuel pressure regulator, also the injectors might not energizing because the computer is not receiving an ignition signal -could be a CPS problem.[/quote:b743418c67]
When you say it could be a CPS problem what do you mean or what does the CPS stand for? Thanks
Sep 15, 2007 at 7:28 AM
  • 75,988 POSTS
[quote:a07170c14c="smylie74"][quote:a07170c14c="rasmataz"][quote:a07170c14c="smylie74"]I have a 2000 taurus, 113,000 miles that is no getting enough feul pressure. I have had it to 4 mechanics and still unable to resolve problem. When driving around 40-55 mph it bogs down, acts like it's running out of gas or it will stall while driving down the road and u have to pump the gas pedal to get it going again. Also sometimes it will idle and sometimes it doesn't weather it's in park or gear and sometimes it doesn't want to start it will just turn over or start for a second but die cause it's not getting enough feul, you can start it with starting fluid though. I have replaced the feul pump and filter twice, the relay switch has been replaced, plugs and wires and injectors cleaned. Please help!!!!!! Thanks for your time in reading my question[/quote:a07170c14c]
What about the fuel pressure regulator, also the injectors might not energizing because the computer is not receiving an ignition signal -could be a CPS problem.[/quote:a07170c14c]
When you say it could be a CPS problem what do you mean or what does the CPS stand for? Thanks[/quote:a07170c14c]
CPS ( Crankshaft Position Sensor ) it tells the computer the position of the piston/engine speed if its missing it will not tell the ICM to fire the coil.
Sep 15, 2007 at 9:57 AM
SMYLIE74
[quote:c6a9e299bb="rasmataz"][quote:c6a9e299bb="smylie74"][quote:c6a9e299bb="rasmataz"][quote:c6a9e299bb="smylie74"]I have a 2000 taurus, 113,000 miles that is no getting enough feul pressure. I have had it to 4 mechanics and still unable to resolve problem. When driving around 40-55 mph it bogs down, acts like it's running out of gas or it will stall while driving down the road and u have to pump the gas pedal to get it going again. Also sometimes it will idle and sometimes it doesn't weather it's in park or gear and sometimes it doesn't want to start it will just turn over or start for a second but die cause it's not getting enough feul, you can start it with starting fluid though. I have replaced the feul pump and filter twice, the relay switch has been replaced, plugs and wires and injectors cleaned. Please help!!!!!! Thanks for your time in reading my question[/quote:c6a9e299bb]
What about the fuel pressure regulator, also the injectors might not energizing because the computer is not receiving an ignition signal -could be a CPS problem.[/quote:c6a9e299bb]
When you say it could be a CPS problem what do you mean or what does the CPS stand for? Thanks[/quote:c6a9e299bb]
CPS ( Crankshaft Position Sensor ) it tells the computer the position of the piston/engine speed if its missing it will not tell the ICM to fire the coil.[/quote:c6a9e299bb]
Thanks I guess that will be the next thing that I check, everything to date has just been feul related. I'll let you know the outcome
Sep 16, 2007 at 3:44 AM
Suggested Repair
Check the fuel pressure regulator and the crankshaft position sensor (CPS). A missing crank signal can keep the computer from energizing the injectors and telling the ignition control module to fire the coil.
Conversation Summary
The owner of a 2000 Ford Taurus with 113,000 miles reports low or no fuel pressure, bogging at 40-55 mph, stalling, intermittent idle, and hard starting, though it will start with starting fluid. The fuel pump and filter were replaced twice, and the relay, plugs, wires, and cleaned injectors did not fix it. The expert suggested checking the fuel pressure regulator and a possible crankshaft position sensor problem that could prevent injector and coil operation. The owner planned to check the sensor next, with no outcome reported.
