2000 Ford Taurus Low Coolant Light
DEEBEE
2000 Ford Taurus 70K Miles. My low coolant light had been coming on occasionally over the past six weeks or so. Happening more frequently now. Coolant reservoir is full , with no apparent leaks. Any ideas what the problem could be? Thanks in advance.
Jan 1, 2007 at 11:07 PM
SERVICE WRITER
  • 9,123 POSTS
Somtimes the sensor will go bad in the reservior. Rap on the sensor lightly and see if anything changes. You have flushed the coolant by now right?
Jan 1, 2007 at 11:08 PM
DEEBEE
No, coolant is still original as far as I know. Where is the sensor located? Thanks again!
Jan 1, 2007 at 11:16 PM
SERVICE WRITER
  • 9,123 POSTS
Get the coolant flushed. The properties of the coolant get diminished and create a situation where you'll have to spend more time here. :)
The coolant level sensor may be part of the cap on the reservior or at the bootmo of the reservior. You see and electrical harness going to it either way. It may not change when you tap on it or it may. I don't recall any other problems that I encountered for triggering that light, unless the reservior was really low.
Jan 1, 2007 at 11:37 PM
Suggested Repair
Flush the original coolant, then inspect the coolant level sensor on the reservoir (in the cap or at the bottom, with an electrical harness). Lightly tap the sensor to see if the warning changes. With a full reservoir and no leaks, a faulty sensor is the likely cause.
Conversation Summary
The owner of a 2000 Ford Taurus reports a low coolant light that comes on more often even though the reservoir is full and there are no visible leaks. The expert says the reservoir level sensor can fail, suggests tapping it, and recommends flushing the original coolant because degraded coolant can lead to further problems. The sensor is typically in the cap or at the bottom of the reservoir and has a wiring harness.
