Heater/Air Conditioner Blower
FORD TAURUS
TWD162
I have a 2000 Ford Taurus SES. My heater - A/C blower stopped working. I replaced a fuse in the Fuse box under the dash (which according to the Owners Manual) was the blower fuse. However this Just gave me high speed blower. I do not have a low or medium blower speed. I have checked every other Fuse I know to check, both under the dash and under the hood. They are OK. What could I check Next? Or what might be causing my Problem? This is my First Post Thanks.
May 30, 2006 at 8:07 AM
LOSONE
  • 1,616 POSTS
You have a bad blower resister. It is located behind the glove box in the blower motor plenum. It is a $15.00 item that takes about 10 minutes to replace. Good luck
May 30, 2006 at 11:10 AM
