1999 Ford Taurus No Heat
BILL51
1999 Ford Tarus 3 liter six cyl 172000 miles Everything works good except the heater. Nothing is stoped up THe water gets hot but it will not blow hot air ? :cry: .
Sep 22, 2007 at 9:52 AM
MERLIN2021
  • 17,250 POSTS
Taurus/Sable these heaters tend to clog up with sludge, feel the both hoses where they go into the core, one will be hot, the other luke warm, if this is true in your case try flushing the core, then Ford has a part that reduces the diamiter of the heater bypass hose, I just clamped mine with a hose clamp plier.
The bypass is the second hose off the waterpump that runs behind the engine to the trany side, try clamping it to see if it brings up your heat...also make sure your antifreeze and thermostat are OK!
Sep 22, 2007 at 10:07 AM
Suggested Repair
Compare the two heater-core hoses; if one is hot and the other lukewarm, flush the heater core. Temporarily clamp the heater bypass hose (the second hose off the water pump running behind the engine toward the transmission) to see if heat improves; Ford offers a reduced-diameter bypass restrictor. Also verify antifreeze condition and the thermostat.
Conversation Summary
The owner of a 1999 Ford Taurus 3.0L says the coolant gets hot but the heater will not blow hot air and believes nothing is clogged. The expert says Taurus and Sable heater cores often clog with sludge, and recommends comparing hose temperatures, flushing the core, restricting the bypass hose, and checking the antifreeze and thermostat.
