2000 Ford Taurus Head Gasket Cost
RWILLIAMSFAM
CAr is 2000 Ford Taurus, 140,000 miles. engine is flex fuel and 6 cylinder. Just replaced belt, coolant tank, spark plugs, and some other things (totalled $900). Car started rough, once idling would settle in. at stops, it would again idle rough and act like it would stall. Temperature would sometimes spike high and smoke would come from engine area. Smell in the car is like a radiator. this morning, car won't start at all. was told head gasket. if that is the case, is there more than one gasket and is it worth repairing? can you estimate cost for me? can you please answer as soon as possible? thanks so much.
Jun 5, 2007 at 6:57 AM
BLACKOP555
  • 10,386 POSTS
not to expensive nor hard job. and yes it is worth repairing!!!!
Jun 5, 2007 at 7:00 AM
RWILLIAMSFAM
How simple is it and what is cost? i need to repair the car but $2000 is what was quoted. is that out of line?
Jun 5, 2007 at 7:10 AM
BLACKOP555
  • 10,386 POSTS
welll its just the cost of the gaskets for the heads.. i wouldnt say it would cost 2000 for the head gasket. not in labor or nuffin unless they really over charge you. do it yourself save some $$$ not to hard of a job either
Jun 5, 2007 at 7:12 AM
RWILLIAMSFAM
to have a mechanic do the job, what do you feel is a fair estimate?
Jun 5, 2007 at 7:27 AM
RUDPRO
  • 224 POSTS
$2000 is probably right. To change an intake manifold gasket at a dealer is $600-$700. The head gaskets are more work. You don't know what they'll find when they take it apart. It may need a valve job and/or lifters too. Call around. Make sure it's a reputable place though. The cheapest price is not always best.
Jun 5, 2007 at 9:31 AM
Suggested Repair
Have a reputable shop confirm the head-gasket diagnosis and quote the repair. About $2000 can be reasonable because the job is more involved than an intake-manifold gasket and may reveal valve or lifter work. Compare quotes rather than choosing only the lowest price.
Conversation Summary
The owner of a 2000 Ford Taurus with rough idle, temperature spikes, engine smoke, a radiator smell, and a no-start was told it might need a head gasket and asked whether a $2000 quote was fair. One reply said the repair was inexpensive and suitable for DIY. Another said $2000 was likely reasonable, noted that dealer intake-gasket work can cost $600-$700, and advised comparing reputable shops because valve or lifter work may also be needed.
