2002 Ford Taurus Idle Power Loss
FORDOWNER
I have a Ford Taurus SE MY2002, 71000 miles. About three weeks ago the car started to make a hi pitched squeaking noise and while idling the car started to lose power frequently. After it happened several times while I am at a traffic light or in the traffic, I checked the belts which seemed fine. Then I checked the throttle body, seemed like the noise was comeing from there. I cleaned the butterfly valve inside the throttle body. The porblem went away including the noise. Then the problem came back again and I cleaned the throttle valve again and it worked. But the problem came back again after two days. Can someone please help me how to fix this problem. Thanks in advance for your help.
Aug 21, 2006 at 10:23 AM
MIKEYBDMAN
  • 623 POSTS
[quote:c917909a8f="FordOwner"]I have a Ford Taurus SE MY2002, 71000 miles. About three weeks ago the car started to make a hi pitched squeaking noise and while idling the car started to lose power frequently. After it happened several times while I am at a traffic light or in the traffic, I checked the belts which seemed fine. Then I checked the throttle body, seemed like the noise was comeing from there. I cleaned the butterfly valve inside the throttle body. The porblem went away including the noise. Then the problem came back again and I cleaned the throttle valve again and it worked. But the problem came back again after two days. Can someone please help me how to fix this problem. Thanks in advance for your help.[/quote:c917909a8f]
THat is a strange one. Have you checked the intake for a vacuum leak? Maybe check your PCV to see if it might be stuck closed.
Aug 21, 2006 at 10:30 AM
Suggested Repair
Inspect the intake for a vacuum leak and check whether the PCV valve is stuck closed.
Conversation Summary
The owner of a 2002 Ford Taurus SE with 71,000 miles reported a high-pitched squeak and frequent loss of power while idling. Cleaning the throttle body butterfly temporarily stopped both symptoms, but they returned after two days. An expert suggested checking the intake for a vacuum leak and the PCV valve for being stuck closed.
