ford taurus 1999 81000 miles
DWAYNEPHILLIPS
need to drain and flush radiator but cannot find a drain plug. If there is one where? If not how do i go about draining radiator?
Nov 18, 2006 at 5:36 AM
BACKYARDMECHANIC
  • 337 POSTS
Dear Rich,
The drain plug is on the bottom of the radiator in either corner. Is tough to find but it is there. Sometimes on the bottom side. (facing the engine )Also sometimes on the bottom of the car there is a plastic shield cover, obstructing the location of the drain plug. If you remove the shield it will make it easier to get to the drain. If all else fails you can remove the lower hose to drain the radiator. Don't recommend doing this way. Very messy and does not drian the system as well.
Good luck Backyardmechanic :)
Nov 19, 2006 at 2:22 AM
