flood water in engine i think
COREY1981
i was driving threw some water n my car cut off i got pushed home, but it started up ,n it was vibrating and smoking can u tell me wats wrong with it 1998 ford taurus v6 engine 135,000mils on it
Oct 23, 2007 at 4:00 AM
98RANGERXLT
  • 301 POSTS
Is it auto or manual air controls
Aug 8, 2007 at 12:32 PM
RKJUDY
[quote:6bf7d1e800="Fordman16"]Is it auto or manual air controls[/quote:6bf7d1e800]I'm sorry, the A/C is the auto temperature control type. You set the temp you want and the unit adjusts. You can also take it out of auto mode and control the fan speed and temp manually. By the way, the same blowing consistency problem occurs in either auto or manual mode. Thanks.
Aug 8, 2007 at 12:42 PM
98RANGERXLT
  • 301 POSTS
The resistor may be going out.
Aug 8, 2007 at 12:51 PM
RKJUDY
[quote:c5bcb60268="Fordman16"]The resistor may be going out.[/quote:c5bcb60268]What should I expect to pay for this repair?
Aug 8, 2007 at 2:25 PM
98RANGERXLT
  • 301 POSTS
I am not too sure you would have to ask one of the moderators either Justanold or Merlin2021 would know
Aug 8, 2007 at 4:34 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like some got in the engine.Pull all the plugs and crank it over to see if any more water comes out.That can do serious damage to the internals in an engine (bend rods, crack crankshafts).
Oct 23, 2007 at 4:02 AM
