1996 Ford Taurus Battery Drain
JAYDADDYPOPS
is it normal to have some kind of drain on your battery from the radio with everything shut off. 1996 ford taurus station wagon
Aug 8, 2007 at 2:42 AM
SERVICE WRITER
  • 9,123 POSTS
There is a normal draw on the battery called a parasitic draw generally around 30 milliamps I believe. This keeps minimum power to modules for memory sake. It shouldn't have an excessive draw however that drains down the battery in a short time.
Aug 8, 2007 at 3:20 AM
Suggested Repair
A parasitic draw of about 30 milliamps is normal to retain module memory. If the battery drains quickly, test for an excessive parasitic draw rather than assuming the radio is the cause.
Conversation Summary
The owner of a 1996 Ford Taurus station wagon asked whether some battery drain from the radio with everything off is normal. The expert explained that a parasitic draw of about 30 milliamps is normal to keep modules powered for memory, but an excessive draw that drains the battery quickly is not.
