1994 Ford Taurus No Crank No Start
OPOTOLO
Ford taurus 1994, milage 72,567. My car wont start at all. when i tunr the key nothing happens no crank, no spark, no noise, no nothing. but i can still lsten to the radio and turn on all the lights and stuff, and i check the gas and i have enough gas. whats wrong?
May 21, 2007 at 2:29 AM
RUDPRO
  • 224 POSTS
I would check the fuses first. There should be a 10 amp ignition fuse. There is also a fuse panel under the hood you might want to check. It should be on the drivers side next to the fire wall.
May 21, 2007 at 3:10 AM
Suggested Repair
Check the fuses first, including the 10 amp ignition fuse and the under-hood fuse panel on the driver's side next to the firewall.
Conversation Summary
The owner of a 1994 Ford Taurus with 72,567 miles says the car will not start: turning the key produces no crank, spark, or noise, while the radio, lights, and other accessories still work and there is enough gas. The expert recommends checking the fuses first, specifically a 10 amp ignition fuse and the fuse panel under the hood on the driver's side next to the firewall.
