2001 Ford Taurus Frozen AC Pulley Fix
Aftermarket clutch and coils don't match up! You would need to remove the compressor to install the coil!
Suggested Repair
Remove the clutch hub (held by an 8mm bolt) and pry it off, then remove the snap ring and pulley. Swap the hub and pulley from a matching junkyard compressor so the R-134a charge is not lost. Aftermarket clutches and coils often do not match; installing the coil requires removing the compressor.
Conversation Summary
The owner of a 2001 Ford Taurus 3.0L asked whether a compressor from a 1992 Taurus would fit after the A/C compressor locked, screeched, broke the belt, and was bypassed with a shorter belt. The pulley is completely frozen, while the hub still turns with effort. The expert recommended swapping the hub and pulley from a junkyard compressor without releasing refrigerant, and warned that aftermarket clutch parts do not match and coil replacement requires compressor removal.
