97 Ford Taurus air locked
1997 FORD TAURUS
PAINTERDUDE
I have a 97 Taurus with a 3.0L and it 120,000 miles on it and I replaced a hose and the thermostat and now I have no heat. I was told that the cooling system is air locked. How do I bleed the cooling system? Thank you in advance for your help!!
Nov 30, 2007 at 5:00 AM
MERLIN2021
  • 17,250 POSTS
With the engine cold remove the radiator cap, squeeze the upper radiator hose a few times while the engine warms. once the water is circulating make sure you fill the system to the highest line on the reservoir, this is a revised instruction by Ford...Also the bypass hose now has a reducer made for it, it as the name impies, shrinks the diameter of the hose to produce more pressure to the heater!
Nov 30, 2007 at 5:13 AM
