i have looked everywhere but i cant find exactly where the cooling fan switch is located. Do you have any idea?
Nov 8, 2008 at 7:58 AM
BMRFIXIT
✓Experienced Mechanic
Coolant temperature sensor
is located at near the thermostat housing
no need for fan switch sensor give reading to the PCM
and when fan s needed the PCM will ground the relay turning on the fans
