1997 Ford Taurus cooling system
1997 FORD TAURUS
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
EZMONEY
  • 10 POSTS
how to purge air from a closed cooling system
Jan 25, 2008 at 3:40 PM
BLACKOP555
  • 10,386 POSTS
Look for a screw/little bolt on top of the thermostat housing or near the upper radiator hose. chances are it will be frozen shut and you will end up stripping it.
best way is remove radiator cap, and put it up on car stands in the front and let the vehicle warm up and run at about 2,000 rpm's and slowly add coolant directly in the radiator till no more bubbles appear.
Jan 26, 2008 at 12:25 AM
