I was told to replace my spark plugs
ZACKMAN
  • 4,202 POSTS
This guide can help help diagrams below to help you on your car.
https://www.2carpros.com/articles/how-to-change-spark-plugs
https://www.2carpros.com/forum/automotive_pictures/55316_99taurussparkplug_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_99tauruscowl_1.jpg
Sunday, May 23rd, 2021 AT 11:42 AM (Merged)
ANDRES1234
  • 1998 FORD TAURUS
  • 6 CYL
  • 86,000 MILES
How do I change the spark plugs at the back of engine at the fire wall. Als o where is the gas filter located.
BMRFIXIT
  • 19,053 POSTS
What do u have for engine (DOHC SOHC )
1.Open hood and remove both windshield wiper pivot arms.
Remove 8 plastic retainers from cowl vent screens to inner panels by turning 1/4 turn counterclockwise.
Remove 5 clips retaining cowl vent screens to inner panels.
Remove left and right side cowl vent screens from vehicle.
Remove 4 bolts retaining ignition coil 4 and position out of the way.
2.Disconnect negative battery cable.
Ensure left and right side cowl vent screens are removed.
Disconnect electrical connector from ignition coil and remove 4 ignition coil hold-down screws.
Remove ignition coil to access spark plugs on cylinders No. 1, 2 and 3.
Disconnect electrical connector from Intake Manifold Runner Control (IMRC) actuator.
Remove IMRC mounting screws, and lay IMRC actuator aside to access spark plugs on cylinders No. 4, 5 and 6.
NOTE: Spark plugs must be marked so they may be installed into the same cylinder from which they were removed.
3.Disconnect ignition wires from all spark plugs.
Loosen spark plugs and use compressed air to remove any dirt or foreign material from spark plug areas of valve covers.
Remove spark plugs.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_118.jpg
TAMI LYNN
  • 1997 FORD TAURUS
  • 3.0L
  • 6 CYL
  • 97,000 MILES
I need a video on how to change the spark plugs and wires on 1997 Ford Taurus station wagon Gl.
Sunday, May 23rd, 2021 AT 11:43 AM (Merged)
Hi Tami,
Here are a couple videos. I assume you are asking because you may have to remove the intake to do the rear? There are tricks but sometimes it is easier to just remove it.
Let me know if you need anything else. Thanks
https://youtu.be/akuAEO7YXwU
https://youtu.be/Wpb-_0wfRnI
BECCA1229
  • 1996 FORD TAURUS
  • 6 CYL
  • FWD
  • 199,000 MILES
My car is a 1996 Ford Taurus LX, I was driving in a passing lane and all of a sudden my rpm went up to 4000 and then there was a bad smell. I pulled over and there was little smoke but not bad. When I looked at the exhaust it was coming out in puff clouds and was actually making a putting noise. I had my husband change the spark plugs and he found one that was not firing and we changed that plug. Now it runs worse than before. My husband thinks that there is a piston that has no fire going to it. Now what?
JGAROFALO
  • 489 POSTS
Start with the basics. Verify with a spark tester that the spark plug is not getting spark. Since your ignition system fires the cylinders in pairs, if one fires and the other does not, there is a possibility of a shorted coil pack.
This guide will help you change the spark plugs correctly.
Also a compression test would be in order. Bad compression will also cause a cylinder not to fire.
Smoke from the tailpipe can also indicate a problem with a head gasket or intake manifold gasket.
