2004 Ford Taurus
DINOMOM66
  • 2004 FORD TAURUS
Engine Performance problem
2004 Ford Taurus 6 cyl Front Wheel Drive Automatic
My daughters 2004 Ford Taurus had been having a decrease in power. It died on her and my husband replaced the alternator. It was clear that it was bad. It is still not running well. When you start it up and riv it some then it dies when you let off the gas. If you get it on the road it runs fine, but when you stop and it will die. It will idle but if you riv it up much or put it in gear then it dies. PLEASE help. She needs her car to get to college and back.
Friday, August 29th, 2008 AT 10:32 PM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.
Saturday, August 30th, 2008 AT 7:47 AM
DINOMOM66
  • 8 POSTS
We replaced the alternator, then it would start but not idle unless you kept it reved up but then it would die after you let off the gas. We replaced the IAC like suggested. Now it will idle a little but still dies. The air conditioner compressor is making a noise and is going out as well. Need help in what to do next!
Thursday, September 4th, 2008 AT 7:59 PM
2CARPRO JACK
  • 11,533 POSTS
I suggested cleaning it out, not replacing it. Is the check engine light on? If so have it scanned for codes, this may help figure out what is wrong. Also look for vacuum leaks, they will affect the idle and power
Friday, September 5th, 2008 AT 7:30 AM
DINOMOM66
  • 8 POSTS
Thank you for all the help. We let it run awhile and it is now idling but not as high as it should. Will this get better with driving it or is ther something else we should do? We know the air conditioner compressor motor is also going out and that makes it sound bad as well. Should we just try running it, I dont want to mess anything up. Thank you in advance.
Wednesday, September 10th, 2008 AT 6:14 AM
2CARPRO JACK
  • 11,533 POSTS
Clean out the throttle bore as well. That will also stabilize idle. Does the car have a tachometer? If so what rpm is it idling at? If the a/c compressor is noisy, you shouldnt use it, as it may be contaminating the system with metal debris, unless it is just the bearing. If it is the bearing, then you need to have it replaced or the belt will fail due to misalignment of the pulleys and that will cause the engine to overheat. Is it always noisy or just with a/c on? If always it is probably the bearing, if only a/c then it is the compressor
Wednesday, September 10th, 2008 AT 7:52 AM
DINOMOM66
  • 8 POSTS
It is noisy all the time. But we found out part of the problem is that it is blowing the A/C clutch relay, PCM keep alive power fuse. Do you think we should replace the compressor or could it be just the bearing? We appreciate all the help!
Tuesday, September 16th, 2008 AT 10:52 PM
DINOMOM66
  • 8 POSTS
If we do replace the compressor, do we also have to replace the accumulator or anything else?
Tuesday, September 16th, 2008 AT 11:02 PM
2CARPRO JACK
  • 11,533 POSTS
Takes alot of special pullers to do just the clutch and bearing.I would probably do the entire compressor. Yes you should replace the accumulator/ receiver dryer as well.
Wednesday, September 17th, 2008 AT 7:50 AM
DINOMOM66
  • 8 POSTS
Okay, we replaced the A/C compressor and the accumulator. We were also told to replace the orfice tube but I can't find where it goes. Please tell me where to find it and how to replace it. I think we are almost done! Thank you for all the help.
Thursday, October 2nd, 2008 AT 7:24 PM
2CARPRO JACK
  • 11,533 POSTS
The tube is located in the high side line that goes from the condensor(in front of radiator) to the evaporator(under dash). You wil have to disconnect the line to find it, it slips inside the hard line. Be sure to note which direction it is pointing so as to reinstall it correctly
Thursday, October 2nd, 2008 AT 8:51 PM
