2003 Ford Taurus panel lights
LJLEXY
  • 2003 FORD TAURUS
  • 6 CYL
  • 135,000 MILES
2003 Ford Taurus. Lights on panel do not work. They willcome on occasionally but at night I can not see how fast I am going, What could cause this?
thank you
ALJ
Sunday, February 15th, 2009 AT 4:03 PM
BMRFIXIT
  • 19,053 POSTS
Possible bad switch and or wiring
check and suspect bulbs in the cluster
Sunday, February 15th, 2009 AT 8:26 PM
LJLEXY
How do I find out how to check for either?
Thank you for your help
Sunday, February 15th, 2009 AT 8:34 PM
BMRFIXIT
  • 19,053 POSTS
Try and move the switch and adjuster to different spots as watching the lights if they come on and or flicker suspect switch remove and check it
if no light and no change
or  lights on in the cluster then I would suspect the light bulbs in the back of cluster
need to remove cluster and replace
Sunday, February 15th, 2009 AT 8:46 PM
