2002 Ford Taurus Dropped door
2002 FORD TAURUS
11,200 MILES • 6 CYL • FWD • AUTOMATIC
FOXMEISTER
Driver's side door lower hinge is worn and the door is not aligned with catch on body. I am going to replace the lower hinge. What is the best way to remover the bolts attaching the hinge to the body?
Thank you
Love to donate but I am unemployed
Jan 24, 2010 at 8:23 AM
BMRFIXIT
  • 19,053 POSTS
DID you try pin kit 1st easier and quicker
https://images.2carpros.com/forum/automotive_pictures/99387_31GfDshrmL__SL500_AA280__1.jpg
Jan 24, 2010 at 9:27 AM
FOXMEISTER
Thanks for replying
I priced out the pin and bushing and there are two reason as to why I want to replace the complete hinge.
1. A used hinge for a 2006 Ford is the same price as the bushing and pin.
2. I would have to remove the hinge in order to replace the pin and bushing. In talking to the Ford people I may have to drill out the hinge bushing hole to make the bushing fit.
So with all that said, I might as well change the complete hinge.
So back to the original question; how do I remove the bolts securing the hinge to the body. There isn't much room.
Regards
Charlie
Jan 24, 2010 at 11:38 AM
