2002 Ford Taurus lights stay on doors won't lock
KIM WILLIAMS
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 85,000 MILES
My car wouldn't start the other day so I wiggled the battery cables and it started. Now when I lock my doors they unlock and the chimes are ringing. Also my interior lights and the lights under my mirror will stay on until I start the car.
Wednesday, June 4th, 2008 AT 7:52 PM
BMRFIXIT
  • 19,053 POSTS
You need to remove and clean the battery terminals
check the starter S small wire connector
also you have a faulty door switch
a scanner will pin point which door
most likely its the driver door
Wednesday, June 4th, 2008 AT 8:08 PM
