2002 Ford Taurus air conditioning clutch
2002 FORD TAURUS
97,000 MILES • 6 CYL • FWD • AUTOMATIC
WANDAE
My air conditioning started blowing hot air. When I stopped at a red light smoke was coming from under the hood and there was a burning smell.
The mechanice tells me my air conditioner clutch is broken, the compressor is locked up and I must replace both at a cost of $700 - $1,000. He also says the car is undriveable because the belt is in danger of breaking.
Does this sound right?
Jul 19, 2008 at 11:47 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:f18d502485="wandae"]Air Conditioning problem
2002 Ford Taurus 6 cyl Front Wheel Drive Automatic 97000 miles
Does this sound right?[/quote:f18d502485]
Yes, it actually sounds a little low. Ask them what all they are going to replace. Because if they don't replace all neccessary components the warrantee will be void. They should flush system replace the compressor and the Accumulater and orifice tube filter.
Jul 19, 2008 at 2:51 PM
WANDAE
thanks
Is there anything speific I need to be looking for from the repair shop?
Approximately how many labor hours should this repair take?
Jul 20, 2008 at 8:18 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:22fbd83069="wandae"]thanks
Approximately how many labor hours should this repair take?[/quote:22fbd83069]
I would just make sure they are replacing all neccessary components so the warrantee on the compressure isn't Voided. As long as they replace all components the warrantee for the whole system should be a year.
The repair work can take up to 8 hours. They have to evacuate the system which will take about an hour. Then replace the components which can take about 4 - 5 hours. Then around 2 hours to recharge the system.
Jul 20, 2008 at 1:23 PM
WANDAE
Thanks so much for your help. I ended up having the car towed to the mechanic I have used before-closer to home. He said the compressor was no longer locked up, but that it did need to be replaced.
Your advice has been very helpful. I knew what to ask and I know what to be sure they do.
Jul 21, 2008 at 12:13 PM
MAGNUSON56
Can you please tell me the final cost and if you purchased new parts or got parts from the junk yard. I just purchased a taurus and noticed this problem as well. I would like to know the amount that i am going to be putting into this.
Thanks
Aug 10, 2008 at 8:36 AM
