I replaced the plugs and wires, I hadn't done it in a while, it needed it, but they didnt look too bad. That didnt work. I replaced the No. 2 fuel injector, that didnt work. I replaced the vaccum lines, but that didnt do anything. It has a coil pack, all 6 on one, so my thinking is, if it was the coil pack, the misfire would atleast be random.
On another note, the low coolant light is on, but there is no coolant loss, and it is pressurized. I think its just a bad sensor, because I had a line break a couple months back, lost coolant, overheated, and when I fixed it, its been on since. That may be about the time the problem started, but I dont know. Also, I ran a vaccum test, and it pulls a solid 22-in steady at idle. No flucutation that would indicate a valve or cylinder problem. I am stumped. Any ideas?
SPONSORED LINKS
Monday, June 23rd, 2008 AT 9:13 PM
