2001 taurus half of the coils are fireing the half are not replace coils same problems what is the problems
Monday, November 1st, 2010 AT 11:20 AM
MECHANIC
Inspect and test the crankshaft position sensor.
SPONSORED LINKS
Tuesday, November 2nd, 2010 AT 2:02 AM
HARTLEYKID
MEMBER
I REPLACD CRANK & crankshaft position sensor STILL SAME PROBLEM CAN YOU HELP ME
Tuesday, November 2nd, 2010 AT 8:15 AM
MECHANIC
You have replaced the cam and crankshaft sensors-if you check the wiring to it for opens and shorts circuits and its good-have the coils driver circuit of the computer checked out-
