We have replaced the over flow tank, not sure if this is what it is called, but this is the third one. It keeps coming out under the cap, the antifreeze isn't over flilled its below the cold line. Why does it, keep doing this, the car is not getting hot when driven, but when you turn it off, then it just bubbles up and fills that tank and comes out then. The only reasone we replaced the tank is because the orginal got a pin hole in it, it doesn't do this all the time. Just can't figure out, Can some one help?
Aug 30, 2010 at 12:54 PM
