Hi there,
I own a 2000 Ford Taurus and I have been having issues with my door locks, where after I get out of the car, the door does not latch on and close at all. This only happens on the drivers side door and no where else on the car.
At first, I thought that this problem was being caused by the cold climate and made sure to lube up all of the hindges. I was also able to get around the problem for a while by using the auto-door lock button and locking/unlocking the door a couple of times, but now that doesn't work at all.
After further investigation, I found that the problem only occurs when I pull on the latch inside of the car to open the door. What happens is that the door lock button stays up and does not go down until I put some force on it. Even when I put force on it, I still need to hit the lock/unlock a few times to make it work. Once I put force on it, the door seams to work again until the next time that I open the door from the inside.
I know this sounds silly but now I open the window, unlock the door and reach out to use the exterior door latch. This is not much of a fix but for the moment I can get out of the car and close my door. Any ideas or what may cause this and how I can fix this issue?
Feb 24, 2007 at 11:40 PM
