The driver side window on a 2003 ford taurus will not come back up. There is a clcking noise coming from under the dash by the door.
Jan 5, 2007 at 3:41 AM
The window motor teeth are likely stripped. Replace the window motor; removing the regulator can be tricky, so use a repair manual for the step-by-step procedure.
The driver-side window on a 2003 Ford Taurus will not go back up, and there is a clicking noise under the dash near the door. The expert said the window motor teeth are probably stripped and recommended replacing the motor with a repair manual because regulator removal can be difficult.
