2000 Ford Taurus Broken Antenna Removal
2000 FORD TAURUS
JTERRAN
Electrical problem
2000 Ford Taurus
I am trying to replace the antenna that was broken off near the base. Online searches have not given me enough detail on how to get the old antenna out. I assume it is held in place by a nut or something underneath in the trunk, but it is behind a metal panel and you can't really see behind it, there is no room to get your head in there.
Sep 5, 2010 at 11:13 AM
BILLYMAC
  • 2,204 POSTS
Do you have a power antenna?
If yes the whole assembly will unbolt use a mirror and a flashlight. to see back there
Sep 5, 2010 at 11:23 AM
JTERRAN
No, it is a basic cheap regular antenna. :)
Sep 5, 2010 at 11:35 AM
BILLYMAC
  • 2,204 POSTS
look at the base of the antenna on the outside of car you should see a round washer type nut it has slots in it you have to unscrew this if it is turning you have to hold it inside with vise grips use a mirror and flash light to look in blind spot
Sep 5, 2010 at 1:06 PM
JTERRAN
Thanks for answering. I had tried to remove that outside washer, but couldn't figure out how. It does not turn at all. It has 4 slots but they are not very deep. I tried using needlenose pliers to grip 2 of them but it diesn't move and then slips out when trying to turn. Any ideas of how to loosen it? I suppose there is some special tool that mechanics have that fits in all 4 slots at once.
Sep 5, 2010 at 2:10 PM
