drivers side window is stuck when i try too raise it up i hear a clicking sound is this easy too fix?
Oct 24, 2008 at 7:21 PM
MASTERTECHTIM
✓Experienced Mechanic
sonds like may be a window regulator problem. these can be tricky to replace, time consuming. first remove the door panel and see if you can see if the window regulator is broken then we can go from there
