1999 Ford Taurus loud squeaking coming from the front end
234,000 MILES • 6 CYL • FWD • AUTOMATIC
VIRGINIA1989
Ok I bought this ford Taurus a few months back very shortly after buying it I noticed the front end squeaking ONLY when I turn it is NOT a whining noise. I took it back to the dealer I bought it off of and he told be that I need to grease the front end...I asked my dad and he said yeah that could be possible. So what I want to know is what’s this noise and if it needs to be greased what is it exactly that needs to be greased?? I appreciate it thanks!!
Feb 8, 2010 at 2:04 AM
BMRFIXIT
  • 19,053 POSTS
Have to have it checked
Suspect tie rod and or ball joint
If have grease fitting should have it greased if not it need to be replaced
Feb 8, 2010 at 1:12 PM
VIRGINIA1989
Well where do I start off....if you were such a car pro you would know that 99 ford taurus' do NOT have grease fittings. and that Ball joits make poping noises NOT SQUEAKING noises. I had to get under my own car to figure out the My year of car does not have grease fittings. And anyone who knows little about cars knows that a popping nose is a ball joint not a SQUEAKING noise!! But thanks for the help anyways.....
Feb 9, 2010 at 1:07 AM
BMRFIXIT
  • 19,053 POSTS
LOL You ask for help only to come back and insult me for trying to help you I do more a day then you seen in your life time
Thank you for the lecture
After market out tie rod end do COME with crease fitting
Lower ball joint do dry out and make a squeaking noise
Feb 9, 2010 at 11:05 AM
