1998 Ford Taurus White Smoke
REDCUTLASS
3.4 V8, Auto trans, 86,000 miles without a major problem until now. Driving started to loose power, SEL came on for a moment, went off and hasn't returned. Borrowed a SO scanner and revealed codes: P0175, P1000, P1116, P1132, P1137, P1138.
Changed out ECT sensor (coolant was green and clear), no change--however haven't rescanned yet--tomorrow. Engine starts up and idles smoothly, for a couple of minutes then starts to smoke (white) and eventually lays down a thick white smoke screen, there seems to be evidence of a fuel smell to the smoke.
Any ideans as to the possible problem and course of action to take is greatly appreciated. Thank you.
Oct 31, 2007 at 3:46 PM
TAURUSWHEEL
  • 718 POSTS
If it's truly white smoke, your're burning coolant, no good.. coolant=white, oil=blue, too much gas=black.. take it to a qualified repair shop and tell them to do a leakdown test to confirm, or not, a blown headgasket(s).
Nov 1, 2007 at 10:13 AM
Suggested Repair
Have a qualified shop perform a leakdown test to confirm or rule out a blown head gasket. Thick white smoke is consistent with burning coolant.
Conversation Summary
A 1998 Ford Taurus SHO with a 3.4 V8 lost power briefly and set codes P0175, P1000, P1116, P1132, P1137, and P1138. After the ECT sensor was replaced, it still idled smoothly for a few minutes, then produced thick white smoke that seemed to smell of fuel. The expert said white smoke indicates burning coolant and recommended a leakdown test to check for a blown head gasket.
