1998 Ford Taurus Speedometer Drops Over Bumps
IDPASSR
Just bought a 1998 SHO. 89k mileage. Noticed something on a recent highway trip. When the car runs over a bump, like the seam in the highway at a bridge, the speedometer needle will drop and then go back to normal. And if you have the cruise control engaged, the engine will race like you were pressing the accellerator.
Under normal driving, cruise control off, nothing happens, but it's kinda annoying when the car feels like it's taking off while the cruise control is on...
Thanks in advance!
George
Dec 15, 2006 at 1:42 PM
CARUNDELL
  • 602 POSTS
[quote:69baaa68c4="idpassr"]Just bought a 1998 SHO. 89k mileage. Noticed something on a recent highway trip. When the car runs over a bump, like the seam in the highway at a bridge, the speedometer needle will drop and then go back to normal. And if you have the cruise control engaged, the engine will race like you were pressing the accellerator.
Thanks in advance!
George[/quote:69baaa68c4]
Hey George,
Interesting problem. Sounds like there could be a loose connection @ the speed control module. I would also check the connections at the speed sensor in the trans. Let us know
Chris
Dec 15, 2006 at 8:14 PM
Suggested Repair
Check for a loose connection at the speed control module and inspect the connections at the transmission speed sensor.
Conversation Summary
The owner of a 1998 Ford Taurus SHO with 89,000 miles reports that the speedometer needle drops briefly when the car hits a bump, such as a highway bridge seam, then returns to normal. With cruise control engaged, the engine races as if the accelerator were pressed. An expert suggested checking for a loose connection at the speed control module and inspecting the connections at the transmission speed sensor.
