1998 Ford Taurus want stay running
TERRYP61
  • 1998 FORD TAURUS
  • 6 CYL
  • FWD
  • 126,000 MILES
Got a 98 taurus and we have pelaced the alternater and battery and mega fuse, and it still want stay running after you take the jumper cables off. Any ideas?
Thursday, November 19th, 2009 AT 8:57 PM
  • 109,787 POSTS
It sounds like you have a ground problem. Check the condition of the ground wire and check where it attaches to the engine block. Make sure it is clean and tight. Also, check body grounds to make sure there are none disconnected, damaged, or broken.
Let me know what you find.
Thursday, November 19th, 2009 AT 10:43 PM
TERRYP61
It wasnt the ground wires. And something must be shorting out somewhere cause it will pull the heck out of my truck when boosting it off. The engine on the taures when running off my truck you can hear it missing a little bit. Man I don't know what else to do
Friday, November 20th, 2009 AT 11:05 AM
