98 Taurus, will either stall while driving, usually when you let off the gas, turning or idling. Or it will not start after you have had it running for w while. I have repleced the fuel filter, IAC (Idle Air Control) valve, battery, and had the alternator checked. It's fine. What is the most probably thing that is wrong that I should replace? Any help will be greatly appreciated.
SPONSORED LINKS
Tuesday, November 17th, 2009 AT 8:06 AM
