1998 Ford Taurus Engine stops while driving down the road
PMORAAB
  • 1998 FORD TAURUS
  • 6 CYL
  • 10,000 MILES
Ignition module/coil pack has been replaced but the enginecontinues to stop while running down road. Engine runs fine when it is cool outside but when it is hot weather it stops. It DOES NOT overheat. Starts back up after a half an hour and runs good.
What could the probem be?
Tuesday, September 23rd, 2008 AT 10:15 AM
BMRFIXIT
  • 19,053 POSTS
Check relays
what do u have for codes ?
after it stalls check fuel pressure and fuel pump
also check for spark
let us now what u have and what is missing and if you have codes
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, September 24th, 2008 AT 6:06 AM
