1998 Ford Taurus lifter test
1998 FORD TAURUS
129,000 MILES • 6 CYL • 2WD • AUTOMATIC
PJANESKI
  • 11 POSTS
Engine in 3.0L OHV. I replaced a piston and connector rod. Engine was still noisy, loud clicking. I am assuming it is a lifter problem.
How do I know which ones are a problem? When I press down on the lifters they don't all react the same way. some are locked into place and some give just a little when I press down on it.
Some forums say they're bad when they move, some say they're bad when they are locked in place.
Is that normal? Which ones should I replace?
Nov 13, 2009 at 7:54 AM
RACEFAN966
  • 5,029 POSTS
It isn't so cut and dry with hydrolic lifters. There is a test procedure you can do and you will need a feeler guage to check them. Here is how it goes. Get number 1 cylinder on TDC compression stroke. Now colapse the intake lifter and measure gap between rocker and valve stem should be .085 to .185 if not then it is valve stem problems and that is the noise. Now as for the lifters the clearence should be .00007 to .00027 that is all the lifter should colapse. Lifters don't cost that much if more then one is bad I would replace them all.
Nov 13, 2009 at 10:07 AM
PJANESKI
  • 11 POSTS
how long does the engine have to run before the lifters will be completely full of oil?
Thanks so much.
Nov 13, 2009 at 5:51 PM
RACEFAN966
  • 5,029 POSTS
Once the oil light is off or the oil pressure guage is up to normal.
Nov 14, 2009 at 8:50 AM
PJANESKI
  • 11 POSTS
Thank you ! This is helpful.
If I may ask - what is the flag in your avatar? I can only make out the colors.
Thanks again.
Nov 14, 2009 at 11:33 AM
RACEFAN966
  • 5,029 POSTS
It it the flag in the shape of Wasington state. It is from the Inland Northwest Mustang Club which I am a part of.
Nov 17, 2009 at 10:04 AM
KMAC1
I have a 97 ford taurus i think the lifters may be bad. car runs pretty good but there is a ticking/squeaking sound coming from the top of the engine. It is not near the belt(left) side but the right side/center. i cant find anything loose, it sounds internal. Any help would be greatly appreciated!
Aug 28, 2012 at 11:19 PM
RACEFAN966
  • 5,029 POSTS
If you think it might be a sticky lifter, then I recomend you pick up a bottle of marvel mystery oil and put in the oil and see if it will help. Let me know how it goes.
Sep 2, 2012 at 2:51 PM
KMAC1
thanks for the info, I will try that next oil change(hopefully!), I just changed the oil and used 25% lucas oil treatment. That did seem to quite the noise a bit. Is lucas comparable to marvel mystery oil?
Sep 3, 2012 at 3:51 PM
RACEFAN966
  • 5,029 POSTS
Yes however marvel is more for cleaning then stabilizing.
Sep 10, 2012 at 4:28 PM
KMAC1
What is your opinion on replacing 2 quarts of oil with 1 quart of lucas and 1 quart of marvel? Thanks again.
Sep 16, 2012 at 2:46 PM
RACEFAN966
  • 5,029 POSTS
It is not a good idea you will add a stabilizer then a cleaner to many additives at one time in my opinion. I would at the correct amount of marvel to you next oil change and see how that does.
Sep 18, 2012 at 2:30 AM
