That is what I needed to know. If the starter does nothing, then we have a few things to check. When it happens, you need to check to see if power it getting to the starter. Have a helper turn the key to the start position while you check for power to the smaller wire on the starter. If should have 12+ volts at that point.
Let me know what you find.
Tuesday, July 27th, 2010 AT 12:10 AM
