HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Cylinder Head
Gasket
Blown
SPONSORED LINKS
1997 Ford Taurus
MATTRESS_KILL
MEMBER
1997 FORD TAURUS
1997 Ford Taurus 6 cyl
how do you repair blown head what needs to be done
Thursday, October 21st, 2010 AT 10:01 AM
MECHANIC
Is the head bad or the gasket?
SPONSORED LINKS
Friday, October 22nd, 2010 AT 7:12 AM
MATTRESS_KILL
MEMBER
Im not sure whats the diffrenece
Friday, October 22nd, 2010 AT 8:44 AM
MECHANIC
If it is only a gasket, it is nothing more than removing and replacing the parts. If the head needs replaced, the new head will require reassembly.
Friday, October 22nd, 2010 AT 10:27 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Blown Content
1997 Ford Taurus Need Answers!
Engine Mechanical Problem 1997 Ford Taurus 6 Cyl Two Wheel Drive Automatic Hello, Im Thinking About Purchasing This Car (see...
Asked by
jnice909
1997
FORD TAURUS
GUIDE
Cylinder Head Gasket Blown Test
Diagnosing a blown head gasket in an automotive engine requires a systematic approach to ensure accurate results. This guide will walk you through the necessary steps to...
1997 Ford Taurus Cooling-overheats
The Car Ran On Upper End Of The Heat Gauge While On The Highway In The Morning But Did Not Overheat Until It Was Driven Through Stop And Go...
Asked by
TWOTAURUS
1997
FORD TAURUS
2001 Ford Taurus Blow Head Gasket
I Have A Blown Head Gasket And I Tried The Blue Devil Two Day Ago It Less Water On One Of The Spark Plug And I Wanted To If It Ok To Try...
Asked by
Sky13
2001
FORD TAURUS
1996 Ford Taurus Possible Blown Head Gasket
My Check Engine Light Is On. A Mechanic Has Shown Me The Computer When He Hooks It Up And It Has Shown, A Miss In One Of The Cylinders And...
Asked by
ontivmi1
1 ANSWER
1996
FORD TAURUS
2003 Ford Taurus Blown Head Gasket
Engine Mechanical Problem 2003 Ford Taurus 6 Cyl Front Wheel Drive Automatic 90k Miles The Car Apparently Got Hot An Seized Up. After...
Asked by
mestill
1 ANSWER
2 IMAGES
2003
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Coolant Mixing with Oil
Hard Starting
Oil Change & Filter Replacement Ford Taurus
Online car repair manuals
