1996 Ford Taurus wont run
154,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKIEGHORLEY
we changed the alternater,then the car became hard to start when it finally did start it didnt want to stay running. when it wont start its not firing, whene it does run the fire is very weak? thanks for the help it was the wiring going to the crank sensor.
Dec 26, 2007 at 8:54 AM
BMRFIXIT
  • 19,053 POSTS
[quote:3ea92b82bb="mikieghorley"]Engine problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 154000 miles
we changed the alternater,then the car became hard to start when it finally did start it didnt want to stay running. when it wont start its not firing, whene it does run the fire is very weak?[/quote:3ea92b82bb]
check wiring and ground
check coil and or replace
Dec 26, 2007 at 9:37 AM
