1996 Ford Taurus Changing a fuel filter
READY
  • 1996 FORD TAURUS
Engine Mechanical problem
1996 Ford Taurus 6 cyl Two Wheel Drive Automatic
Thanks for every body who gave me suggestions but I still can't remove the fuel filter. I removed the hairpin clips, de-pressureized the system, pulled and twisted the fuel line till the car shook but still it won't come loose. I think I need to use the tool to release the spring in the fuel line but their is no room for the tool to fit. Someone even told me that the tool wasn't even used in this situation. I have the tool and it doesn't even come close to fitting. Do you think I could just cut the fuel line, splice the line and just use hose clamps to complete the job.
And ideas please. Thanks, Jim
Saturday, March 27th, 2010 AT 7:03 PM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic_60.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_701.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_321.jpg
use the correct tool should release it
Cutting the fuel line is not recommended as you have a high pressure fuel and will come off
Causing fire
Putting yourself in a very dangerous situation
Sunday, March 28th, 2010 AT 8:30 AM
