Cooling fans not working?
WILLIE3
  • 1996 FORD TAURUS
Cooling fans not working, fuse in engine compartment check good, radiator rodded out last october, thermostat working, when car gets hot fans do not run,
Thank You
Monday, June 15th, 2009 AT 9:07 PM
JGAROFALO
  • 489 POSTS
Engine coolant temperature sensor is suspect. The fans do not come on until a pre-programmed temperature is reached. It should be around 200 degrees F. You can check fan operation by turning on the A/C. Fan(s) should come on with the compressor. These guides can help fix it
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
and
https://www.2carpros.com/articles/replace-electric-fan-motor
Thursday, June 18th, 2009 AT 4:18 PM
